TIME iNTERVAL REGISTRATION
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by PcB » Wed Aug 23, 2017 9:52 pm
timeinterval registration for scientific using of sound registring , including naming progressing, filetyp and saving place...
- Load, Save ( a registerd or set a new timeinterval registrationcard)
- Registercard name
- Set period from to as data and time or endless with no start end button or controlled with start end button without start and end date
- set registering time of x time then make pause of x time, repeat it or not
- set Input from x chanel
- set all sound qualitys including possibilitys for all spec or min max frequenz, set +- 20db input
- set file name = x-y as x=yourename and y =number from 1to x OR registering initdate = yyyy-mm-dd-hh-mm-ss (yourename-2017-08-23-22-20-12.mp3
- set type of file mp3, wav, xxx
- set place to save files
- if endless then show start end button to start and end the registering
- give a information how big one file wil be to check up avaiable space
I need this to have a instrument to register noise but need only each 10 minut 1 minut of registring from to date as progresive named files in mp3
so could someone implement these or give me info if there exists a sofware to use fot that
thnaks
Marc
PcB
Re: TIME iNTERVAL REGISTRATION
Permanent link to this post Posted by kozikowski » Thu Aug 24, 2017 4:45 am
So you and the surveillance people. Automatic management and time stamping is the holy grail.
Permanent link to this post Posted by steve » Thu Aug 24, 2017 8:06 am
I don't know of any GUI program that meets your specification (on any platform), but on Linux you could use:
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 8 guests
