Audacity Spectral Analysis bug
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by mr123 » Tue Jul 11, 2017 10:11 am
Hello!
I send an email to the email suggested in the wiki but the answer said to post here instead.
Just downloaded Audacity today and have a bug like this:
Inline images 1
Installation details:
Version: 2.1.2
Downloaded: using apt install audacity
OS: Ubuntu 16.10 64bit
What I did: Open a .mp3 file, select an area and choose Analyze->Plot Spectrum...
Problem: Described in the above picture. The window is transparent/nothing is shown. If I move it, it starts flickering.
What I've tried:
Restarting audacity
Loading the file with File->Open or just dragging it
Sudo apt update &sudo apt upgrade (Audacity stayed at version 2.1.2 and problem persisted)
Rebooting OS
Since I've had graphical issues with my laptop previously, I'll list some hardware details as well:
Intel Core i3-6100
Intel HD graphics 520
8GB RAM
PS.
First time running the program, the window started flickering right away with some actual frequency plotted (see attached video).
The same happened after apt upgrade.
Best regards,
MR
Inline Image:
Video:
https://www.dropbox.com/s/38hgfi8lcnu9n ... 4.mp4?dl=0
mr123
Re: Audacity Spectral Analasys bug
Permanent link to this post Posted by mr123 » Tue Jul 11, 2017 12:07 pm
Since it was asking me to update to 17.04 for a while now, I figured I'd get it out of the way.
Since upgrading Ubuntu to 17.04, I've not experienced the problem anymore. However, there might be people still left on 16.10 for whatever reason.
mr123
Re: Audacity Spectral Analysis bug
Permanent link to this post Posted by Gale Andrews » Tue Jul 11, 2017 12:22 pm
Moved to correct board.
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 7 guests
