need speed
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
need speed
Permanent link to this post Posted by autodctr » Tue Jul 04, 2017 5:31 pm
Audacity 2.1.2 and Xubuntu 16.04 64 bit. I need to record 18 channels of music via USB cable from a mixer. I have a 1TB spinning drive running the program and a 120G SSD to record it onto. I went into Preferences and chose the SSD drive for the temp file. Is this correct? Is this the fastest means of recording to make sure that I don't have to drop the quality? My issue has always been trying to get enough throughput to the HD.
I had actually gone backwards before to Xubuntu 14.04 and an older version of Audacity because it worked where the new version did not. But lately, I can no longer edit the recordings made on the older Audacity version on the new version: when I try to play something, it skips ahead about 20 seconds before actually playing.
Thanks in advance.
autodctr
Re: need speed
Permanent link to this post Posted by Trebor » Tue Jul 04, 2017 7:22 pm
autodctr wrote:need speed
Set the CPU frequency (clock speed) governor to "performance".
Give Audacity higher CPU priority (less nice).
Trebor
Re: need speed
Permanent link to this post Posted by autodctr » Tue Jul 04, 2017 8:07 pm
Actually, CPU time is not the issue. When I am recording, the CPU is running at about 10 %, memory usage is around 880 meg, and 0 swap. I am running a 3.3 quad core.
What I noticed: with the older Audacity 2.0.?, when I finally stop the recording after about 15-20 minutes of recording, the HD runs crazily for about a minute before I am able to save the file. With the newer version of Audacity, I can save the file instantly. What I am supposing here is that the old version was "stringing" everything together AFTER the recording was stopped whereas the newer version does the stringing while recording. Therefore, I am assuming that this is where the problem lies: the HD is not fast enough to lay down all that info. So, that is why I have put an SSD drive into the machine. I do not yet know whether that is going to do the trick or not. I was just trying to understand exactly how and where Audacity buffers to and records to.
Right now, I have the spinning HD running the program and the SSD recording the soundtrack. I could have the program run and record from the SSD if someone tells me that is a better way. But again, the writing of the soundtrack is where *I* believe the bottleneck occurs.
autodctr
Re: need speed
Permanent link to this post Posted by autodctr » Tue Jul 04, 2017 8:19 pm
This is an older post about this problem: viewtopic.php?f=48&t=91897&p=307807&hilit=autodctr#p307807. If the sound clips are still there, you can hear what I was getting while recording: and that was with the recording quality settings brought down quite a bit with really no difference from what Audacity used as default when installed.
autodctr
Re: need speed
Permanent link to this post Posted by autodctr » Tue Jul 04, 2017 8:20 pm
One last thing: a 15 minute recording (on the older version) @ 18 channels, comes out to about a 6 gig file.
autodctr
Re: need speed
Permanent link to this post Posted by Trebor » Tue Jul 04, 2017 9:24 pm
autodctr wrote:One last thing: a 15 minute recording (on the older version) @ 18 channels, comes out to about a 6 gig file.
I'm awestruck that you can get Audacity to record 18 channels.
Within an Audacity-project the audio is stored at 32-bit-depth, (no matter the bit-depth of the capture).
18 mono channels at 44100Hz 32bit is ~80Mb per minute, for 15 minutes is 2700Mb = 2.7Gb
Maybe you're recording at higher-rate than the standard 44.1kHz,
96kHz sample rate would give 5.88Gb for 15 minutes, that's close to your "6 gig".
Trebor
Re: need speed
Permanent link to this post Posted by autodctr » Tue Jul 04, 2017 10:46 pm
18 stereo channels, hence the 6G size. Or there abouts.
Anyway, I am still trying to find out what the best set-up is for attempting it, if someone has any ideas.
I did it before with the older version. Now, I have better PC, better HD (SSD), and I am hoping to accomplish this. The SSD is hooked to a 6G SATA port. I just have no other ideas other than trying to find out exactly where Audacity buffers/records the info.
I have the program on the spinner HD, the temp directory for Audacity on the SSD. I am hoping that this is the correct/best option.
autodctr
Re: need speed
Permanent link to this post Posted by autodctr » Tue Jul 04, 2017 10:49 pm
Recording was at 44.1 with 32 bit float. What else can I tweak if I need to? I am hoping not to drop below 44.1 one for several reasons: I want the quality and even when I tried that before it really didn't help.
autodctr
Re: need speed
Permanent link to this post Posted by autodctr » Sun Jul 09, 2017 3:20 pm
No joy today. Even with the SSD, I still could not record 18 channels even after dropping the to frequency to 22.1 and using the lowest sampling rates.
autodctr
Re: need speed
Permanent link to this post Posted by steve » Sun Jul 09, 2017 4:51 pm
Have you tried using Jack Audio System?
http://jackaudio.org/
Next
Return to GNU/Linux
Who is online
Users browsing this forum: No registered users and 3 guests
