Freezing when moving audio to different track.
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by baillou2 » Fri Jun 16, 2017 2:08 pm
At some point within the past few days I've run into an issue. Whenever I try to move a bit of audio from one track to another Audacity freezes once the track is moved. I can only then close the program and restart.
I run a version of Arch on my laptop and so it's quite possible there was an update that broke something. But does anyone have any ideas on what could be causing this and how to fix it? It makes editing all but impossible now.
Thanks.
baillou2
Re: Freezing when moving audio to different track.
Permanent link to this post Posted by Gale Andrews » Sat Jun 17, 2017 11:43 am
Where does Audacity come from? Is it an ancient version supplied by arch? See the pink panel at the top of the page for how to give us your Audacity version number. If the tracks are at different sample rates it could be a resampling problem.
Perhaps you should try building Audacity from source code: http://www.audacityteam.org/download/source/.
Return to GNU/Linux
Who is online
Users browsing this forum: No registered users and 2 guests
