Scrip for Auto Noise reduction
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade (see
Permanent link to this post Posted by rathore » Wed May 31, 2017 11:57 am
Hi Guys
i am new to this forum and looking for help or support to remove the noise from recorded files , details are as below
We have 1000s of audio files produced daily in our call center. We need to remove (using sox/audacity or any other script) 2-3 types of voices in the background.
Script / Cron Tasks
-Automatically scan and remove all unwanted background noise for all audio files being stored on the recording server
-Save file in the original format by deleting the original file on the recording server
-highly efficient and timed process to ensure load balancing on server
Sample 20 files will be given for batch processing. If the result of those samples is acceptable we will award the project.
The Server is Linux based.
Re: Scrip for Auto Noise reduction
Permanent link to this post Posted by steve » Wed May 31, 2017 12:10 pm
I think SoX will be your better option. Their noise reduction effect is documented here: (see: "noisered")
There are some example bash scripts that you may find helpful here: ... 28&t=53669
Return to GNU/Linux
Who is online
Users browsing this forum: No registered users and 2 guests
