Ubuntu 16.04 - missing libavcodec.so.54?
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by Shrdlu » Mon May 29, 2017 10:02 am
Since upgrading to *buntu 16.04 I am unable to run Audacity:
Code: Select all
audacity: error while loading shared libraries: libavcodec.so.54: cannot open shared object file: No such file or directory
I can't install that version of libavcodec:
Code: Select all
$ sudo apt-get install libavcodec54
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package libavcodec54 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libavcodec54' has no installation candidate
LibAV is installed:
Code: Select all
$ sudo apt-get install libav-tools
libav-tools is already the newest version (7:2.8.11-0ubuntu0.16.04.1).
libav-tools set to manually installed.
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
I have tried purging and re-installing Audacity to no avail. Any ideas?
Shrdlu
Re: Ubuntu 16.04 - missing libavcodec.so.54?
Permanent link to this post Posted by Gale Andrews » Mon May 29, 2017 3:30 pm
Have you upgraded to the packaged version of Audacity in the 16.04 repository? Note that Audacity Team is not responsible for such packages - they are the responsibility of Canonical.
If you updated to Ubuntu 16.04 over previous Ubuntu, this is deprecated by Canonical and likely to create issues. Save your data and do a fresh overwrite install instead from the 16.04 image file.
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 4 guests
