file names missing or not showing correctly in Import>Audio
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Re: file names missing or not showing correctly in Import>Au
Permanent link to this post Posted by Gale Andrews » Thu Mar 23, 2017 2:28 pm
labud wrote:I have wxWidgets 3.0 devel already installed on opensuse 42.2 will that conflict with wxWidgets 2.8.12?
Not if you follw the instructions I suggested:
Audacity should find the install of wxWidgets in usr/local, but if not, you can add the path to the WX_CONFIG file in your 2.8.12 wxWidgets installation to your configure command as described in the link above http://wiki.audacityteam.org/wiki/Developing_On_Linux.
Permanent link to this post Posted by labud » Fri Mar 24, 2017 12:09 am
running into problems compiling wxWidgets 2.8.12
downloaded [wxGTK, 13 MB] and ran
Code: Select all
./configure --enable-shared
had to do this a couple of times as I was missing somethings [its been a while sine I compiled anything]
with that completed I moved on to
Code: Select all
make
I am receiving an error:
Code: Select all
[email protected]:~/Downloads/wxGTK-2.8.12> make
/home/dabud/Downloads/wxGTK-2.8.12/bk-make-pch ./.pch/wxprec_basedll/wx/wxprec.h.gch wx/wxprec.h g++ -I./.pch/wxprec_basedll -D__WXGTK__     -DWXBUILDING -I./src/tiff -I./src/jpeg     -I./src/expat/lib -DwxUSE_GUI=0 -DWXMAKINGDLL_BASE -DwxUSE_BASE=1 -fPIC -DPIC -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -I/home/dabud/Downloads/wxGTK-2.8.12/lib/wx/include/gtk2-ansi-release-2.8 -I./include -pthread -I/usr/include/gtk-2.0 -I/usr/lib64/gtk-2.0/include -I/usr/include/pango-1.0 -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/libdrm -I/usr/include/libpng16 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16 -I/usr/include/pango-1.0 -I/usr/include/harfbuzz -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -DWX_PRECOMP -pthread -O2 -fno-strict-aliasing
In file included from ./include/wx/wxprec.h:13:0:
./include/wx/defs.h:212:26: error: redeclaration of C++ built-in type ‘bool’ [-fpermissive]
     typedef unsigned int bool;
Makefile:11973: recipe for target '.pch/wxprec_basedll/wx/wxprec.h.gch' failed
make: *** [.pch/wxprec_basedll/wx/wxprec.h.gch] Error 1
Do you know what this means? I have no clue and I don't want to quit in the middle of getting it done. I have googled to no avail, mostly thru my lack of understanding the ERROR. There does not seem to be anything in usr/local at this point, but maybe because I am not finished?
I have gone thru the dependencies list you provided and all is good there, when I finally compile Audacity 2.1.0
labud
Operating System: GNU/Linux other
Permanent link to this post Posted by Gale Andrews » Fri Mar 24, 2017 5:02 pm
labud wrote:running into problems compiling wxWidgets 2.8.12
Code: Select all
Have you got the gtk2-devel package installed?
I'm afraid I don't really know niceties of compiling widgets on openSUSE. You could try
Code: Select all
configure --enable-unicode --enable-shared
ANSI is default in wx2.8 rather than Unicode, if I recall correctly. Also the Audacity default configure is for Unicode so configuring widgets for unicode will save you changing the Audacity configure.
If you still get stuck perhaps it would be an idea to ask on the openSUSE forums.
Permanent link to this post Posted by labud » Sun Mar 26, 2017 8:28 pm
OK got wxWidgets installed. the added
Code: Select all
--enable-unicode
worked.
Checked all dependancies and all their devel counterparts- all installed.
Followed directions on link provided for compiling of Audacity 2.1.0.
This is my output with an ERROR at the bottom:
Code: Select all
[email protected]:~/Downloads/audacity-minsrc-2.1.0> ./configure CXXFLAGS=”-std=gnu++11″
configure: loading site script /usr/share/site/x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking how to create a ustar tar archive... gnutar
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether NLS is requested... yes
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for ld used by GCC... /usr/x86_64-suse-linux/bin/ld
checking if the linker (/usr/x86_64-suse-linux/bin/ld) is GNU ld... yes
checking for shared library run path origin... done
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking for C compiler vendor... gnu
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for ar... ar
checking the archiver (ar) interface... ar
checking how to print strings... printf
checking for a sed that does not truncate output... /usr/bin/sed
checking for fgrep... /usr/bin/grep -F
checking for ld used by gcc... /usr/x86_64-suse-linux/bin/ld
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/x86_64-suse-linux/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for archiver @FILE support... no
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... failed
checking for sysroot... no
checking for mt... mt
checking if mt is a manifest tool... no
checking for ANSI C header files... no
checking for sys/types.h... no
checking for sys/stat.h... no
checking for stdlib.h... no
checking for string.h... no
checking for memory.h... no
checking for strings.h... no
checking for inttypes.h... no
checking for stdint.h... no
checking for unistd.h... no
checking for dlfcn.h... no
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/x86_64-suse-linux/bin/ld) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking whether the g++ linker (/usr/x86_64-suse-linux/bin/ld) supports shared libraries... yes
libtool.m4: error: problem compiling CXX test program
checking for g++ option to produce PIC...  -DPIC
checking if g++ PIC flag  -DPIC works... no
checking if g++ static flag  works... no
checking if g++ supports -c -o file.o... no
checking if g++ supports -c -o file.o... (cached) no
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking how to hardcode library paths into programs... unsupported
checking for pkg-config... yes
checking whether the linker accepts the -rdynamic flag... no
configure: WARNING: "Linker does not support -rdynamic. Could not enable exporting all symbols"
configure: WARNING: "Audacity module support will probably not work"
checking for an ANSI C-conforming const... no
checking for size_t... no
checking for alloca.h... no
checking for libudev.h... no
checking CFLAGS for strict prototypes... no, suppressed, signal.h
checking wall_flags for maximum warnings... -Wall
checking whether the C++ compiler accepts the  -Wall flag... no
checking whether the C++ preprocessor accepts the  -Wall flag... yes
checking whether the -Werror option is usable... no
checking for simple visibility declarations... no
checking for wx-config... /usr/local/bin/wx-config
configure: Checking that the chosen version of wxWidgets is 2.8.x
Great, you're using wxWidgets 2.8.12!
configure: Determining what libraries are available in this tree and on the system
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for EXPAT... yes
configure: Expat libraries are available as system libraries
checking for ./lib-src/expat/lib/expat.h... no
configure: Expat libraries are NOT available in the local tree
checking for AVCODEC... no
checking for AVFORMAT... no
checking for AVUTIL... no
configure: FFmpeg library NOT available as system library
checking for ./lib-src/ffmpeg/libavcodec/avcodec.h... yes
checking for ./lib-src/ffmpeg/libavformat/avformat.h... yes
configure: FFmpeg headers are available in the local tree
checking for lame_set_VBR_q in -lmp3lame... no
checking lame/lame.h usability... no
checking lame/lame.h presence... no
checking for lame/lame.h... no
configure: LAME library is NOT available as system library.
checking for ./lib-src/lame/lame/lame.h... yes
configure: LAME headers are available in this source tree.
checking for FLAC... no
configure: FLAC/FLAC++ libraries are NOT available as system libraries
checking for ./lib-src/libflac/include/FLAC/format.h... no
checking for ./lib-src/libflac/include/FLAC++/decoder.h... no
configure: FLAC libraries are NOT available in this source tree
checking for ID3TAG... yes
configure: Libid3tag libraries are available as system libraries
checking for ./lib-src/libid3tag/frame.h... no
configure: libid3tag libraries are NOT available in the local tree
checking for LIBMAD... yes
checking for mad_decoder_init in -lmad... no
configure: WARNING: system installation of libmad found, but it is too old.  Upgrade to at least 0.14.2b to use with Audacity
configure: libmad libraries are available as system libraries
checking for ./lib-src/libmad/frame.h... no
configure: libmad libraries are NOT available in the local tree
checking for ./lib-src/libnyquist/nyx.h... yes
configure: nyquist libraries are available in the local tree
checking for ./lib-src/libresample/include/libresample.h... no
configure: libresample libraries are NOT available in the local tree
checking for LIBSAMPLERATE_SYSTEM... yes
configure: Libsamplerate libraries are available as system libraries
checking for ./lib-src/libsamplerate/src/samplerate.h... no
configure: libsamplerate libraries are NOT available in the local tree
checking for SBSMS... no
configure: Libsbsms libraries are NOT available as system libraries
checking for ./lib-src/sbsms/include/sbsms.h... yes
configure: libsbsms libraries are available in the local tree
checking for SNDFILE... yes
configure: Libsndfile libraries are available as system libraries
checking for ./lib-src/libsndfile/src/sndfile.h.in... no
configure: libsndfile libraries are NOT available in this source tree
checking for SOUNDTOUCH... yes
configure: Libsoundtouch libraries are available as system libraries
checking for ./lib-src/soundtouch/include/SoundTouch.h... no
configure: libsoundtouch libraries are NOT available in the local tree
checking for SOXR... no
configure: Soxr libraries are NOT available as system libraries
checking for ./lib-src/libsoxr/src/soxr.h... no
configure: libsoxr libraries are NOT available in the local tree
checking for LIBTWOLAME... yes
configure: Libtwolame library available as system library
checking for ./lib-src/twolame/libtwolame/twolame.h... no
configure: libtwolame library is NOT available in the local tree
checking for VAMP... no
configure: Vamp libraries are NOT available as system libraries
checking for ./lib-src/libvamp/vamp-hostsdk/PluginLoader.h... no
configure: Vamp libraries are NOT available in the local tree
checking for LIBVORBIS... yes
configure: Vorbis libraries are available as system libraries
checking for ./lib-src/libvorbis/include/vorbis/vorbisenc.h... no
checking for ./lib-src/libogg/include/ogg/ogg.h... no
configure: Vorbis libraries are NOT available in this source tree
checking for LV2... no
configure: LV2 libraries are NOT available as system libraries
checking for ./lib-src/lv2/configure... no
configure: LV2 libraries are NOT available in the local tree
checking for PORTAUDIO... yes
configure: portaudio19 library is available as system library, but does not have the Pa_GetStreamHostApiType function.
checking for ./lib-src/portaudio-v19/include/portaudio.h... yes
configure: portaudio19 library is available in the local tree
checking for PORTSMF... no
configure: portSMF library is NOT available as system library
checking for ./lib-src/portsmf/allegro.h... yes
configure: portSMF library is available in the local tree
checking for WIDGETEXTRA... no
configure: libwidgetextra library is NOT available as system library.
checking for ./lib-src/lib-widget-extra/NonGuiThread.h... yes
configure: libwidgetextra library is available in the local tree
configure: Figuring out what libraries to enable
configure: Using SYSTEM libraries for EXPAT
configure: Using LOCAL libraries for FFMPEG
configure: Using LOCAL libraries for LAME
configure: disabling LIBFLAC
configure: Using SYSTEM libraries for LIBID3TAG
configure: Using SYSTEM libraries for LIBMAD
configure: Using LOCAL libraries for LIBNYQUIST
configure: disabling LIBRESAMPLE
configure: Using SYSTEM libraries for LIBSAMPLERATE
configure: Using LOCAL libraries for LIBSBSMS
configure: Using SYSTEM libraries for LIBSNDFILE
configure: Using SYSTEM libraries for LIBSOUNDTOUCH
configure: disabling LIBSOXR
configure: Using SYSTEM libraries for LIBTWOLAME
configure: disabling LIBVAMP
configure: Using SYSTEM libraries for LIBVORBIS
configure: disabling LV2
configure: Using LOCAL libraries for PORTAUDIO
configure: Using LOCAL libraries for PORTSMF
configure: Using LOCAL libraries for WIDGETEXTRA
configure: EXPAT: adding  to libraries
configure: LIBID3TAG: adding  to libraries
configure: LIBMAD: adding  to libraries
configure: LIBSNDFILE: adding  to libraries
configure: LIBSOUNDTOUCH: adding  to libraries
configure: LIBTWOLAME: adding  to libraries
configure: LIBVORBIS: adding  to libraries
checking for library containing dlopen... no
configure: error: dlopen not found, required by Audacity
Code: Select all
Where/what is the library containg dlopen. On googling, I that if glibc and/or all *-devel's are not installed this could cause this error, but I have double checked the dependencies list and all is good there.
I have tried to findout more about dlopen, but nothing pertinent to my situation comes up.
Can you tell me what/where opendl is and how do i get it?
Thanks
labud
Permanent link to this post Posted by Gale Andrews » Mon Mar 27, 2017 5:03 pm
As I say, I am not familiar with openSUSE. Its exact Audacity dependencies may differ from what is listed in our Wiki. Are you sure you installed glibc and glibc-devel?
Otherwise, I think you need to raise the question on the openSUSE forums.
Let us know how you get on.
labud wrote:OK got wxWidgets installed. the added
Code: Select all
--enable-unicode
worked.
Code: Select all
Code: Select all
Thanks
Previous
Return to GNU/Linux
Who is online
Users browsing this forum: No registered users and 3 guests
