Markers tracks steals shorcuts
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by xX0v0Xx » Sun Mar 05, 2017 4:28 pm
Hello Guys.
Using Audacity 2.1.2 (see below the system info) on a
Linux xxxxxx 4.4.0-49-generic #70-Ubuntu SMP Fri Nov 11 16:39:33 UTC 2016 i686 i686 i686 GNU/Linux
from ubuntu packages.
Here is my (small) concern.
I mainly use the shortcuts and especially 'r' to start record. That works OK as soon as you DON'T have a marker track on the project.
As soon as you added the markers track it take precedence of the keyboard.
When I strike ''r'" the markers track just "steals" the keyboard and start to write a new marker. Obviously this is not what I want!
I tried various things but nothing works here. Any idea guys how to block the markers track to take keyboard focus for itself ?
Thanks
Informations système
Support de format de fichier
libmad
(Importation de MP3)
Activé
libvorbis
(Import et Export Ogg Vorbis )
Activé
libid3tag
(support des tag ID3)
Activé
libflac
(Import et Export FLAC)
Activé
libtwolame
(export MP2)
Activé
QuickTime
(Importer depuis QuickTime)
Désactivé
ffmpeg
(Import/Export FFmpeg)
Activé
gstreamer
(Import via GStreamer)
Désactivé
Bibliothèques
libsoxr
(Conversion de fréquence d'échantillonnage)
Activé
PortAudio
(Lecture et enregistrement audio)
v19
wxWidgets
(Cross-platform GUI library)
3.0.2
Fonctions
Nyquist
(Prise en charge des greffons)
Activé
LADSPA
Activé
Vamp
Activé
Audio Units
Désactivé
VST
Activé
LV2
Activé
PortMixer
(Support du mixage de la carte son)
Activé
SoundTouch
(Support du changement de hauteur et de tempo)
Activé
SBSMS
(Support du changement extrême de hauteur et de tempo)
Activé
Date de création du programme :
Jan 29 2016
Commit Id:
No revision identifier was provided
Type de version :
Distribution
Préfixe d'intallation
/usr
Répertoire de paramêtres :
/home/xxxxxx/.audacity-data
xX0v0Xx
Re: Markers tracks steals shorcuts
Permanent link to this post Posted by steve » Sun Mar 05, 2017 4:51 pm
The behaviour should depend on which track has "focus".
The track with focus is the "current" track - it has a yellow border. The Up/Down cursor keys move focus from one track to another.
If a label track has focus, then that label track should get keyboard input and behave as you describe.
If the label track does not have focus (for example, if an audio track has focus), then the label track should not get the key presses and shorcuts should work.
Permanent link to this post Posted by Gale Andrews » Mon Mar 06, 2017 4:29 am
When 2.1.3 is released there is a new option in Tracks Preferences "Type to create a label". If you uncheck that option, shortcuts won't create a new label even if the yellow focus border is in the label track. The downside is that you must use CTRL + B first to create a new empty label (or use Edit > Paste Text to New Label) if there is text on the system clipboard).
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 2 guests
