Override track
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Override track
Permanent link to this post Posted by sciurius » Mon Feb 27, 2017 10:53 am
Hi,
Given two (stereo) tracks, each containing a recording of the same piece of music. What is the easiest way to select (the best) parts from both track to form a new track? Schematically ( | are cross-over points)
Code: Select all
track 1:    xxxxxyy|yyyzz|zzzxxxxxy|yyy|yzzzzz
track 2 :   eeeeeee|aaaaa|ggggggggg|bbb|hhhhhh
result:     xxxxxyy|aaaaa|zzzxxxxxy|bbb|yzzzzz
Cut and paste is a possibility, but then I would prefer something similar to a track pair, where the first track always sounds unless there is something non-empty in the second track (wich would then sound instead). For example:
Code: Select all
track 1:    xxxxxyyyyyzzzzzxxxxxyyyyyzzzzz
track 2 :          aaaaa         bbb
result:     xxxxxyyaaaaazzzxxxxxybbbyzzzzz
I can simulate something like this with envelopes, but this is not easy since both envelopes are independent.
sciurius
Re: Override track
Permanent link to this post Posted by steve » Mon Feb 27, 2017 11:12 am
One way of doing it:
Code: Select all
Make a "Split" at each "|".
To do that:
  • select, for example the "yyyzz" section,
  • then press "Shift+Ctrl+K" to extend the selection to all tracks (alternatively, "Down cursor" to move to the next track, then "Enter" to toggle the selection on).
  • press Ctrl+i (Split tracks)
Repeat for each section.
Then silence each part that you don't want:
  • Double click on the audio clip
  • Ctrl+L
Tip: If you get a split in the wrong place, you can either "Undo" (Ctrl+Z) or "Join" the adjacent clips by clicking on the split line.
Try to place the clips during silences so as to avoid clicks at the edit positions.
Re: Override track
Permanent link to this post Posted by sciurius » Mon Feb 27, 2017 3:30 pm
Thanks for the valuable tips.
I hoped it would be possible to have movable split points, to fine-tune the exact location of the split.
sciurius
Re: Override track
Permanent link to this post Posted by sciurius » Mon Feb 27, 2017 6:11 pm
Alternatively:
Code: Select all
The (audible) result can also be obtained by making the splits as you suggested, and then mute the undesired parts. I know how to remove (Split Cut) such a part, or to silence it. Is it possible to mute them?
sciurius
Re: Override track
Permanent link to this post Posted by steve » Mon Feb 27, 2017 6:28 pm
There's no facility to mute individual clips, only tracks. You can however copy, duplicate or move clips from one track to another.
To drag a clip to a new empty track, use the Time Shift tool.
To drag vertically only (no change to time position), hold down the Ctrl key then drag while holding down the key.
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: Google [Bot] and 5 guests
