ExportWAV using FFmpeg won't export 24 bit
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by anechoic » Tue Feb 21, 2017 6:24 pm
I create a new chain using the ExportWAV
parameters for ExportWAV can't be set in chain edit box so...
I create a dummy file with a sine wave
set export params using Custom FFmpeg export from pulldown in save dialog
Open Custom format options in same dialog box
set to wav and pcm_s24le
close dummy wav file
go to Apply Chain
set to folder of aiff files
hit "OK"
exports to a new folder called "cleaned"
check the files using "sndfile-info" on command line
all the files are 16 bit as seen here
File : myfilepath/cleaned/myfile.wav
Length : 118327284
RIFF : 118327276
WAVE
fmt : 16
Format : 0x1 => WAVE_FORMAT_PCM
Channels : 2
Sample Rate : 44100
Block Align : 4
Bit Width : 16
Bytes/sec : 176400
data : 118327240
End
is this a known bug using FFmprg?
thanks!
KC
anechoic
Operating System: Linux Mint
Re: ExportWAV using FFmpeg won't export 24 bit
Permanent link to this post Posted by steve » Tue Feb 21, 2017 6:33 pm
anechoic wrote:is this a known bug using FFmprg?
It's a "limitation".
The only export options that are currently supported in Chains are those that are listed in the interface. FFmpeg is not currently supported at all in Chains, but I shall log your interest in this feature on the Audacity wiki "Feature Requests" page.
Permanent link to this post Posted by steve » Tue Feb 21, 2017 6:35 pm
steve wrote:I shall log your interest in this feature on the Audacity wiki "Feature Requests" page
"Vote" added.
Permanent link to this post Posted by anechoic » Tue Feb 21, 2017 8:25 pm
thanks! I ended up using the "other uncompressed files" to do what I needed but having access to FFmpeg would be very handy as would being able to set params using ExportWAV :)
anechoic
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: silenteditor and 2 guests
