audacity library for recording
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by naseeb_panghal » Fri Feb 17, 2017 9:59 am
I can record audio successfully using audacity tool but i want all this with a program. Is there any audacity library which i can use to get recorded data in a buffer and do further processing myself?
Currently i can get it with arecord/aplay utilities but they are giving single channel data although i am setting -channel=2. Quality of audacity tool is very good thats why i am looking for audacity library or any audacity-devel package.
Kindly suggest.
Best Regards,
Naseeb Panghal
naseeb_panghal
Operating System: Linux Fedora/RHEL
Re: audacity library for recording
Permanent link to this post Posted by steve » Fri Feb 17, 2017 10:37 am
naseeb_panghal wrote:Is there any audacity library which i can use to get recorded data in a buffer and do further processing myself?
Audacity uses PortAudio http://www.portaudio.com/
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 2 guests
