Recording with Firebox through Jack and FFado
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by autumnleaves » Sat Jan 21, 2017 9:24 pm
Can someone direct me to detailed instructions for setting up Audacity 2.1.2 to record from Firebox. Presumably Jack and FFADO are the only alternatives available, or am I wrong? I have tried the latter but having a lot of problems. One Audacity related issue is that it seems to be no longer possible to record from the Firebox and monitor through an ALSA output, since ALSA output is no longer available when Firebox is activated now (unlike previous versions). Can QJackCTL be used to run Jack to allow ALSA output via patching? Thank you for your attention.
autumnleaves
Operating System: Linux Mint
Re: Recording with Firebox through Jack and FFado
Permanent link to this post Posted by steve » Sun Jan 22, 2017 2:59 pm
I'm not quite sure what you are asking.
I presume that you are referring to a PreSonus Firebox? Does it work at all on your computer with any software?
Permanent link to this post Posted by autumnleaves » Mon Jan 30, 2017 2:55 pm
Yes, I do have it working (Jackd+FFADO Mixer+Audacity), but the gain is quite low. I'm wondering if I might be doing something wrong.
autumnleaves
Permanent link to this post Posted by steve » Mon Jan 30, 2017 6:21 pm
autumnleaves wrote:Yes, I do have it working (Jackd+FFADO Mixer+Audacity), but the gain is quite low.
Have you tried enabling the +12 dB boost? (the manual is available here: http://www.presonus.com/products/FireBox/downloads)
Permanent link to this post Posted by autumnleaves » Wed Feb 01, 2017 1:53 pm
I guess this is the source of the problem. I don't think the Presonus windows software runs on Linux.
autumnleaves
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 5 guests
