Ubuntu 16.04 Audacity 2.1.2
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Re: Ubuntu 16.04 Audacity 2.1.2
Permanent link to this post Posted by bentsu » Sat Oct 21, 2017 4:42 pm
Sorry, I only now found dracconi had that mic. My mic is a cheap 10€ Labtec and jack type.
It has been working earlier many years also with Audacity. And it is functioning presently with Skype.
Might be that combination with Skype is causing some problem?
(Skype for Linux beta 5.4.0.1) However Skype is usually not on or open at all except
on certain times.
All the sounds coming through the computer can be recorded without any problem but
the system does not recognise mic input with Audacity.
So the mic recording is still the problem.
bentsu
Permanent link to this post Posted by steve » Sun Oct 22, 2017 12:24 am
bentsu wrote:Sorry, I only now found dracconi had that mic
This is the problem with tagging onto the end of someone else's topic - the problem may seem similar, but usually the details are different, so very often the similarity is only superficial and the cause / solution can be totally different. This is why we generally prefer to have a new thread for each problem.
bentsu wrote:Might be that combination with Skype is causing some problem?
Skype is quite aggressive in how it handles the sound system and is well known for causing problem in other audio programs while it is running. Even when 'dormant' in the background it can cause problems.
bentsu wrote:All the sounds coming through the computer can be recorded without any problem but
Assuming that you are using Ubuntu 16.04, open the Sound Settings and look in the "Input" tab. Ensure that mic is enabled and that the meter is responding to your voice when you talk into the mic. Is that much working?
Permanent link to this post Posted by bentsu » Mon Oct 23, 2017 1:24 pm
steve wrote:Assuming that you are using Ubuntu 16.04, open the Sound Settings and look in the "Input" tab. Ensure that mic is enabled and that the meter is responding to your voice when you talk into the mic. Is that much working?
Yes the mic is working in all the other instances. However, any Audacity settings show no mic life and the meter is not responding.
Audacity working fine in-line.
bentsu
Permanent link to this post Posted by steve » Mon Oct 23, 2017 2:48 pm
Open "Help menu > Audio Device Info", and when the info opens, click the "Save" button.
Attach the saved file to your reply
(see here for how to attach files to forum posts: https://forum.audacityteam.org/viewtopi ... 49&t=64936 )
Permanent link to this post Posted by bentsu » Tue Oct 24, 2017 6:20 am
I removed Skype. That was at least one solution as Audacity is working now also via mic.
bentsu
Previous
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 5 guests
