Ubuntu 16.04 Audacity 2.1.2
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Re: Ubuntu 16.04 Audacity 2.1.2
Permanent link to this post Posted by dracconi » Fri Jul 15, 2016 3:00 pm
@Gale
heres my output, yes
audio:x:29:pulse
My ubuntu is 16.04 LTS
dracconi
Permanent link to this post Posted by Gale Andrews » Sat Jul 16, 2016 12:29 pm
dracconi wrote:audio:x:29:pulse
That looks normal.
You did not tell us where you got Audacity from. If you built it yourself you may not have built it correctly.
I would shut down all other applications that are using your sound card. Open System Monitor and shut down any audio daemons that may be running. Then Audacity should be able to use the sound card.
Or backup your data to a USB drive or similar and reinstall Ubuntu into a fresh partition on your computer. You said it was a fresh installation, but I can tell you that a few people have had messed up audio in 16.04 when they upgraded directly over a previous Ubuntu version. Ubuntu no longer recommend overwrite installations.
Permanent link to this post Posted by dracconi » Sun Jul 17, 2016 1:28 pm
@gale I SAID it's pure installation. Again, after shutting all apps that might using audio nothing changed. Should i reinstall it? I'm using apt package manager to install it.
Also I'm using cinnamon 3.0.
Theres a warning
(audacity:16023): IBUS-WARNING **: Unable to connect to ibus: Could not connect: Connection refused
dracconi
Permanent link to this post Posted by Gale Andrews » Mon Jul 18, 2016 12:05 pm
It's up to you if you reinstall Audacity. I doubt it will make any difference, from your description. "Something" is preventing Audacity accessing any devices so you need to find what that something is.
If you do reinstall the 2.1.2 package supplied by Ubuntu, first delete the ~/.audacity-data/ folder so that the new installation has clean settings.
If there is a glitch in the 2.1.2 package supplied by Ubuntu, remove it and try the 2.1.2 Ubuntu Handbook PPA instead: https://launchpad.net/~ubuntuhandbook1/+archive/ubuntu/audacity.
The IBUS-WARNING is "normal". IBus a multi-lingual input method not related to audio.
Permanent link to this post Posted by dracconi » Tue Jul 19, 2016 12:18 pm
@Gale
Reinstalling after removing this repo didn't change nothing.
dracconi
Permanent link to this post Posted by Gale Andrews » Tue Jul 19, 2016 2:52 pm
dracconi wrote:@Gale
Exactly what did you reinstall? You could uninstall the Ubuntu 2.1.2 repo version and install the 2.1.2 Ubuntu Handbook version.
You could open a terminal, type:
Code: Select all
aplay -l
hit ENTER and post what that says. See aplay man page.
You may be better asking on the Ubuntu forums. There is a reason Audacity sees no devices. There may be a sound daemon we don't know about which you enabled by accident.
Permanent link to this post Posted by dracconi » Thu Jul 21, 2016 9:45 am
@Gale
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC269VB Analog [ALC269VB Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: GoMic [Samson GoMic], device 0: USB Audio [USB Audio]
Subdevices: 1/1
dracconi
Permanent link to this post Posted by Gale Andrews » Thu Jul 21, 2016 11:47 am
What version of Audacity did you reinstall, exactly?
You have playback devices.
And
Code: Select all
arecord -l
should show you recording devices.
If Audacity still does not see those devices, type this in a terminal and hit ENTER
Code: Select all
ps -A > ps.txt
This saves a list of your running processes to the file "ps.txt" in the folder the command prompt was at.
Post the file "ps.txt" on the Ubuntu forums and ask if any of those processes would prevent pulse accessing the sound device.
Permanent link to this post Posted by bentsu » Sat Oct 21, 2017 3:20 pm
I found this old thread when trying to find solution to my problem which seems to be the same as
"dracconi";s. All the details are the same on my set up too.
Is there any further info in this matter?
bentsu
Permanent link to this post Posted by steve » Sat Oct 21, 2017 3:56 pm
bentsu wrote:I found this old thread when trying to find solution to my problem which seems to be the same as
Test your Samson Go mic on another computer.
PreviousNext
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 3 guests
