No sound. Cursor stops.
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux.
Please state:
Permanent link to this post Posted by raphaelsilva00 » Mon Apr 11, 2016 1:41 am
I was playing a song on Audacity and it was working fine. When I clicked on the timeline to move the playing location, I got a message that the playback device could not be loaded. Then, no more sound. I restarted Audacity, and the device I had been using ("HDA [something I don't remember]") was gone, and now I can only choose between "pulse" and "default" (from Alsa). When I try either one, the audio plays for like 50 milliseconds, and then the cursor stands still forever (as well as the volume bars), and no audio comes out anymore.
The program itself doesn't crash or freeze.
Any ideas?
Thanks.
raphaelsilva00
Re: No sound. Cursor stops.
Permanent link to this post Posted by raphaelsilva00 » Mon Apr 11, 2016 3:06 am
Just after I clicked the "Submit" button to create this topic, I had an idea, and it worked: I ran Audacity with the command
env PULSE_LATENCY_MSEC=300 audacity
Works perfectly now!
raphaelsilva00
Return to GNU/Linux
Who is online
Users browsing this forum: No registered users and 2 guests
