Hi
Using the Audio Device Info crasher Audacity with VIA 8237 sound, Im using Puppy Linux Slacko 531. Audacity 2.00 and 2.01 behave similarly. Audio Device Info works okay with Creative Labs soundcard and Puppy Slacko.
Using JACK set to hw0,0 the error is still there, but setting JACK to hw0,1 makes it work okay. Here is a summary and commandline output-
Audacity with ALSA, Audio Device Info crash
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 3875
audacity: pcm_params.c:2249: snd1_pcm_hw_params_slave: Assertion `err >= 0' failed.
Aborted
Audacity with JACK, JACK set to hw0,1, Audio Device Info no crash
Audacity with JACK, JACK set to hw0,0, Audio Device Info no crash
ALSA lib pcm_dsnoop.c:612:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm_dmix.c:1018:(snd_pcm_dmix_open) unable to open slave
Aborted
The selection of input device changes depending on the above settings, see screenshots
