I just started playing around with Oracle’s VM Virtualbox within Linux Mint 13 (Mate). I’ve installed Windows XP successfully and everything seems to work fine so far. Since I’ve been unable to use Audacity for recording (Line In) in Linux, I attempted to install the Windows version in Virtualbox. It installed fine but won’t start. I get the following error message:
C:Program FilesAudacityaudacity.exe
This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.
I tried reinstalling but to no avail. Any thoughts and/or advice would be appreciated.
Thanks in advance.
