Frequent crashes in Audacity 1.3.13-beta on Linux Mint 11 64
Hi everybody,
I’ve got problems with Audacity 1.3.13-beta on Linux Mint 11 64-bit, as it freezes and then crashes when I’m listening some playback.
Here’s what happening:
 _________________________________________
/ People are beginning to notice you. Try
 dressing before you leave the house.    /
       ___
     {~._.~}
      ( Y )
     (_)-(_)
ale@beast ~ $ audacity
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2212:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
bt_audio_service_open: connect() failed: Connessione rifiutata (111)
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4537
warpfactor 1,000000, stoptime 203,636468, warpstoptime 203,636468
Expression 'parameters->channelCount <= maxChans' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1434
Expression 'ValidateParameters( outputParameters, hostApi, StreamDirection_Out )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1776
Does that output all occur when you launch Audacity, or does some of it occur only when Audacity freezes/crashes?
What options do you have in the Device Toolbar playback options?
