audacity 2.0 svn on Ubuntu 10.04 (SOLVED)
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by rj45_user » Fri Mar 23, 2012 2:50 am
Hi Audacity folks,
I was able to download the 2.0 SVN code and compile on Ubuntu 10.04 (Lucid) (x86-64)
after installing all of the wxwidgets 2.8.12 code.
Couple of minor problems:
Since my (and AFAIK every) Ubuntu distro uses PulseAudio, I get a bunch of
ALSA errors when launching Audacity 2.0. I dont' know if I have a bunged up
Alsa config, but these line seems to be the key:
Expression 'stream->capture.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 3857
Audacity 2.0 actually can capture an input stream fine when newly lanuched, but sometimes I have to relaunch it
when it messes up.
It can't seem to find my FFMPEG libs, even though I downloaded source, compiled and installed them.
(Of course I've tried setting the lib manually) Doesn't seem to matter much, though. Should it?
The menus tend to disappear sometimes. I can usually do something and get wxwidgets to refresh them.
Looking forward to trying the improved noise reduction, among other goodies. :mrgreen:
regards,
rj45
rj45_user
Re: audacity 2.0 svn on Ubuntu 10.04
Permanent link to this post Posted by steve » Fri Mar 23, 2012 12:37 pm
rj45_user wrote:Expression 'stream->capture.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 3857
That's normal. It's just an information message, not an error message.
This is what I get when launching Audacity if Jack is not running:
Code: Select all
ALSA lib pcm.c:2190:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2190:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2190:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Cannot connect to server socket err = No such file or directory
jack server is not running or cannot be started
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 3875
Expression '*idev = open( idevName, flags )' failed in 'src/hostapi/oss/pa_unix_oss.c', line: 811
Expression 'OpenDevices( idevName, odevName, &idev, &odev )' failed in 'src/hostapi/oss/pa_unix_oss.c', line: 857
Expression 'PaOssStream_Initialize( stream, inputParameters, outputParameters, streamCallback, userData, streamFlags, ossHostApi )' failed in 'src/hostapi/oss/pa_unix_oss.c', line: 1234
And this is what I get when launching Audacity when Jack is running:
Code: Select all
Permanent link to this post Posted by steve » Fri Mar 23, 2012 2:50 pm
rj45_user wrote:It can't seem to find my FFMPEG libs, even though I downloaded source, compiled and installed them.
FFmpeg can be a pain because of dependencies.
I believe that FFmpeg is included in the Audacity dependencies, and the standard Ubuntu distro version of FFmpeg should work fine with Audacity 2.0.
The easiest way to satisfy all of the dependencies in Debian based distributions is to use:
Code: Select all
sudo apt-get build-dep audacity
If you ran "sudo make install" to install Audacity, run "sudo make uninstall" to uninstall it.
Ubuntu installs the repo version of Audacity into /usr/ but the default configuration for the source code is /usr/local/
If you configure Audacity to install in /usr/ then Audacity should automatically find any LADSPA plug-ins that you have installed.
If you don't do this and want to use LADSPA plug-ins you need to add a LADSPA_PATH environment variable, or move any repository installed LADSPA plug-ins to a location where Audacity will find them. See here for more details: http://wiki.audacityteam.org/wiki/Ladspa_Plug-ins
Before building Audacity again I'd suggest running "make distclean" which will remove both the built files and the previous configuration. Then run ./configure --prefix=/usr/
To summarise,
1) Remove your custom build of FFmpeg.
2) Install dependencies using:
Code: Select all
3) Open a Terminal window in the root of the Audacity source code.
4) enter the following commands:
Code: Select all
sudo make uninstall
<password>
make distclean
make
sudo make install
<password>
If you find that Audacity still does not find FFmpeg after doing this, please post the contents from Audacity "Help menu > Show Log".
Permanent link to this post Posted by bgravato » Fri Mar 23, 2012 5:48 pm
rj45_user wrote:The menus tend to disappear sometimes. I can usually do something and get wxwidgets to refresh them.
I think that is a known issue. Probably related to this bug: http://bugzilla.audacityteam.org/show_bug.cgi?id=458
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
bgravato
Permanent link to this post Posted by rj45_user » Sat Mar 24, 2012 1:05 am
Thanks guys!
I have so much respect for the great work in FOSS Audacity, and depend on it constantly.
Steve, your suggestions were perfect. Audacity now finds the ffmpeg libs fine.
warm regards,
don (rj)
rj45_user
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 6 guests
