Audacity-2 for x68-64 ?
Help for Audacity 2.x.x on GNU/Linux.
ImageThis forum is for Audacity 2.x.x on GNU/Linux and Unix-like operating systems.
Please state which version of Linux you are using, the exact three-section version number of Audacity from Help > About Audacity... and whether you installed your distribution's release or daily version of Audacity or compiled Audacity from source code.
Permanent link to this post Posted by bvv2001 » Tue Mar 20, 2012 11:12 pm
I use Slackware-13.1 x86-64 version. Then I do compile new version audacity for my PC I take this error
Code: Select all
configure: Checking that the chosen version of wxWidgets is 2.8.x
configure: error: Unable to locate a suitable configuration of wxWidgets v2.8.x or higher.
The currently available configurations are listed below.  If necessary, either
install the package for your distribution or download the latest version of
wxWidgets
from http://wxwidgets.org.
    Default config is gtk2-unicode-2.9
  Default config will be used for output
BUT wx-config --version-full give me 2.9.1.0 and wx-config --version - 2.9.1
What I do wrong?
bvv2001
Re: Audacity-2 for x68-64 ?
Permanent link to this post Posted by steve » Tue Mar 20, 2012 11:43 pm
Does your WxWidgets installation include the development headers?
Another possibility is that 2.9.1 may be too recent - the most recent version that I've tried is 2.8.12.
Permanent link to this post Posted by bvv2001 » Wed Mar 21, 2012 4:56 pm
In slackware soft installation FOREVER with development headers. Downgrade version wxWidgets? This is very-very bad idea. If I do it my another software my be broken (
bvv2001
Permanent link to this post Posted by Gale Andrews » Wed Mar 21, 2012 7:12 pm
Can you do (as root):
Code: Select all
apt-get build-dep audacity
on Slackware (if you have not already)? That should show you if dependencies are missing.
Certainly on Windows, Audacity cannot be built against wx 2.9 without many changes, and that may be true on other platforms, but your error isn't saying that (yet). If you still have a problem please post your configure input.
If it is needed to build Audacity against wx 2.8.12 then compile and install 2.8.12 separately and do something like the following when configuring Audacity:
Code: Select all
WX_CONFIG=/usr/local/bin/wx-config ./configure
where /usr/local/bin has the 2.8.12 install.
Permanent link to this post Posted by bgravato » Wed Mar 21, 2012 11:35 pm
Gale Andrews wrote:Can you do (as root):
Code: Select all
As far as I'm aware, I think Slackware doesn't use apt. Well at least it didn't in the old days...
Apt package manager is usually only used by Debian and Debian-based distros, such as Ubuntu.
According to wikipedia (about Slackware's package management):
The package management system does not track or manage dependencies, instead it relies on the user to ensure that the system has all the supporting system libraries and programs required by the new package. If any of these are missing, there may be no indication until the newly installed software is used.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
bgravato
Permanent link to this post Posted by bgravato » Wed Mar 21, 2012 11:38 pm
Like Gale said you can build a local copy of an older wxwidgets version and place it in a different directory, then build audacity against it.
In which case is probably good idea to build it statically so it doesn't depend on dynamic libs to be run and you should then be able to safely remove the unwanted wxwidgets version.
bgravato
Return to GNU/Linux and Unix-like
Who is online
Users browsing this forum: No registered users and 3 guests
