Importing Labels
I am very new to Audacity and am currently just “playing” with audio that I have around the house not particularly for any reason.
MACOS 10.13.4
Audacity 2.2.2
I have created a file using text wrangler (now BBedit) saving it as Windows CRLF UTF-8, the file tease the form:
Time in HH:MM:SS.xxx (tab) Time in HH:MM:SS.xxx (Tab) Label Title
Ive tried to import this originally with seventeen labels in that format each one on a new line, this failed so I tried it with just one… I get the same rather unhelpful error every time and I am hoping someone more experienced can provide some guidance…
The error I receive is simply this:-
“One or more save labels could not be read”
Any ideas?
Ian
Try saving the file as plain ASCII text with “LF” line endings.
Steve, I cant see an option in either BBedit or TextEdit that is “Plain ASCII” but I have opened and saved the file using MacVIM which should be plain text - I still get the same message.
Ian
If you attach the text file to your reply, I’ll take a look. (see here for how to attach files to forum posts: https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1 )
This is the simplest version of the file with just one label.
Label_Import_Test.txt (38 Bytes)
Times must be in seconds, relative to “0.0” on the Timeline).
If you want that label at “28 seconds”, you should write it as
28
or
28.0
or
28.000
1 min 35.6 seconds would be written as:
95.6
or
95.600000
(trailing zeros are unimportant).
