Audio files not importing
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by Joak » Sun Apr 15, 2018 1:22 pm
Hello,
I really hope this is the right area to post this.
I used audacity previously to clean up some audio for a video project and it worked out pretty well. But today I tried to import some audio files to tweak before syncing with video and it didn’t work.
I attempted to drag the file into audacity and it didn’t do anything. The loading window popped up briefly, showing the load data (or whatever you call it) for like a second and then...nothing.
I attempted to import via file>import and the same thing. Didn’t work.
Any chance I could get a little help?
Thanks
Joak
Re: Audio files not importing
Permanent link to this post Posted by Trebor » Sun Apr 15, 2018 3:25 pm
You have to install something called FFmpeg into Audacity before it can play some audio formats, & rip the audio from some types of video files, see ...
https://manual.audacityteam.org/man/installing_and_updating_audacity_on_mac_os_x.html#macff
Trebor
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 3 guests
