reduce size of wav file in 2.2.2
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by brianentz » Fri Apr 13, 2018 8:07 am
I have a voice recording that must be reduced in size. It must be a wav file. how to do this? :?
brianentz
Re: reduce size of wav file in 2.2.2
Permanent link to this post Posted by steve » Fri Apr 13, 2018 11:35 am
If it's stereo, you could make it mono (reduces the size by half).
If it's a high sample rate, you could reduce the sample rate.
If it's high bit-depth, you could reduce the bit-depth.
If ADPCM encoding is acceptable, you could convert to ADPCM encoded WAV.
What's it for?
Where did the WAV file come from?
What is the full and exact specification for the file format that you want?
What is the format now?
Permanent link to this post Posted by brianentz » Fri Apr 13, 2018 2:25 pm
Its a wav file. Its a vocal only outgoing message for a phone voicemail. So quality is not that important. Mono and lo fi is fine. How do I do those things you mentioned.
brianentz
Permanent link to this post Posted by kozikowski » Sun Apr 15, 2018 5:06 am
If it's stereo, use the drop-down menu to the left of the track > Split stereo to Mono.
[X] delete one of the two tracks.
Use the Project Sample Rate lower left Audacity Window and reduce the sample rate until you get what you want.
File > Export > Export WAV
At 8000, the sound is a little better than a telephone.
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
