I know I likely botched this one since I can't find anything that has worked in the forum so far, but I thought I would check.
I just finished a long editing session and exported the file. It came up with a message that I now realise suggested I change the file name because it made it seem like it had an extension other than mp3. But like an idiot I didn't read it and assumed that it was just a message asking if I was sure I wanted to save over the existing file.
I now have a file saved on my computer with no obvious file extension that seems to think .041118 is the extension.
I tried importing as raw data and it's just noise.
Is there any way to rescue this or am I re-editing the whole thing?
BTW - Didn't save an audacity file because I thought I was done. Using a mac on El Capitan.
Thanks for any advice.+
