RECORD LEVEL ON MAC HIGH SIERRA 10.13.4
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by JOE C » Thu Apr 12, 2018 4:29 pm
Just installed Audacity 2.2.2 and recording volume slider is inaccessible and locked at high end. Pop up says to use system audio mixer but I cannot locate one in Sound preferences or Audio Midi Setup utility. Has anyone else run into this or have a solution? Thanks.
JOE C
Re: RECORD LEVEL ON MAC HIGH SIERRA 10.13.4
Permanent link to this post Posted by billw58 » Thu Apr 12, 2018 9:27 pm
You must be using a USB sound device. Please have a look at this page and see if it helps.
billw58
Permanent link to this post Posted by JOE C » Thu Apr 12, 2018 11:58 pm
Yes, I'm using a USB Electro Brand turntable. I tried the directions at the link you included but they didn't help. The options in the configuration dropdown of the audio midi setup utility are all greyed out.
JOE C
Permanent link to this post Posted by billw58 » Fri Apr 13, 2018 12:54 am
The point is that you can't adjust the recording level when using a USB audio device. The only way to control the recording level is to control the level going into the device. This is not a fault in Audacity.
-- Bill
billw58
Permanent link to this post Posted by JOE C » Fri Apr 13, 2018 8:11 am
Okay. Thanks.
JOE C
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
