USB Codec for mac?
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
USB Codec for mac?
Permanent link to this post Posted by momusic » Wed Apr 11, 2018 12:01 am
Running High Sierra 10.13.4 on 2.7 GHz intel. Connecting with "V.TOP" model AV202 usb audio capture analog to digital device.No usb codec shows up. Have tried system prefs> sound. Device shows up as "USB PnP Audio Device". Went to MIDI setup, same results. "USB PnP Audio Device" shows up in Audacity pulldown as well. Recording from turntable. Audacity DOES record, however the sound level is so low it barely registers in the window. I DO have the record level cranked all the way up. Any way to get and install the elusive USB code for mac?
momusic
Re: USB Codec for mac?
Permanent link to this post Posted by kozikowski » Wed Apr 11, 2018 12:16 am
It doesn't have to say USB Audio CODEC. The manufacturers can call it anything they want. You should find some name that comes and goes when you connect and disconnect the turntable.
Permanent link to this post Posted by momusic » Wed Apr 11, 2018 2:21 am
The "PnP Audio Device" does come up on the device list, and I do select it with the volume slider all the way to the max but still have the very low volume input. It barely registers on the Audacity window.
momusic
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
