Can a USB Audio Codec be installed on a Mac ?
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by VinylPort » Mon Apr 09, 2018 10:06 am
Hello
I was wondering if a USB audio codec can be installed on a Mac running Snow Leopard ? Or do I have to buy a new version of Mac OSX ?
Any info is appreciated
VinylPort
Operating System: OS X 10.6 Snow Leopard or earlier
Re: Can a USB Audio Codec be installed on a Mac ?
Permanent link to this post Posted by billw58 » Mon Apr 09, 2018 5:34 pm
Snow Leopard is 10.6. You can upgrade for free, but it takes two steps. See this page from Apple.
How does this relate to Audacity? Are you trying to record from an external USB audio converter? If so, which make and model.
Also, what Mac are you using. Not all can be upgraded to 10.13.
Does the information on this page help?
-- Bill
billw58
Permanent link to this post Posted by VinylPort » Mon Apr 09, 2018 9:14 pm
billw58 wrote:Snow Leopard is 10.6. You can upgrade for free, but it takes two steps. See this page from Apple.
-- Bill
Hello
Thanks for the reply. I tried to download the MacOS High Sierra but it said my computer is not compatible. I was thinking of downloading Mac OSX Lion but I am not sure if the USB Audio Codec is in there. I bought the Behringer UFO 202 as an external USB converter. I looked at those page that you referred to but the Audio Codec is not on my computer at all.
VinylPort
Permanent link to this post Posted by VinylPort » Mon Apr 09, 2018 9:40 pm
Also
I am using a MacBook from 2007, is has Mac OS X 10.6.8, Processor: 2.16Ghz Intel Core 2 Duo, Memory: 4 GB 667 MHz DDR2 SDRAM
VinylPort
Permanent link to this post Posted by billw58 » Tue Apr 10, 2018 3:16 am
Have you plugged the UFO202 into the computer? "USB Audio CODEC" will not show up in System Sound Preferences until you do.
-- Bill
billw58
Permanent link to this post Posted by kozikowski » Tue Apr 10, 2018 5:32 am
I think you're working too hard.
Plug the UCA-202 into your machine and let it settle for a bit.
Apple (upper left) > System Preferences > Audio > Input. Somewhere in that list it should say USB Audio CODEC. If you send sound into the UCA-202, the Mac bouncing light sound meter should bounce. (Click the graphic if it doesn't fit).
Screen Shot 2018-04-09 at 22.26.15.png (58.93 KiB) Viewed 110 times
If you get it that far, start or restart Audacity. Look in the device toolbar and the USB Audio CODEC should be there.
Screen Shot 2018-04-09 at 22.29.05.png (23.73 KiB) Viewed 110 times
Get it that far?
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
