Trivial error when recording from a mic
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by gualivchenko » Sun Apr 08, 2018 4:51 pm
Hello!
I'm using a Scarlett Focusrite as the input. Using Mono track recording and a directional mic.
Just recording my voice on Audacity on a macOS High Sierra.
I have the latest mix control installed.
The direct output of the interface works perfect.
But when I capture the input from Audacity, I get this sound (listen to attached ogg)
I'm relatively new to sound editing so this may be trivial. However I read a lot and I couldn't find my issue.
Any help is appreciated.
Thanks
hello.ogg
Sounds like with too much gain or broken, but sounds perfect on the direct interface output.
(29.47 KiB) Downloaded 6 times
gualivchenko
Re: Trivial error when recording from a mic
Permanent link to this post Posted by kozikowski » Sun Apr 08, 2018 6:38 pm
What kind of machine is it and what's the microphone? I'm typing this on a Mac Mini.
Permanent link to this post Posted by gualivchenko » Sun Apr 08, 2018 8:01 pm
Computer: MacBook Pro (Retina, 13-inch, Early 2015)
Mic: Pyler PDMIC58
gualivchenko
Permanent link to this post Posted by kozikowski » Sun Apr 08, 2018 8:39 pm
Cool.
Until we get used to you, your postings will require an elf OK to be visible.
See if you can record from your MBP internal microphone. Change the recording setting in the toolbars.
Screen Shot 2018-04-08 at 13.37.12.png (8.13 KiB) Viewed 126 times
Permanent link to this post Posted by gualivchenko » Sun Apr 08, 2018 8:50 pm
Ok.
Just tested and the built-in mic works fine...
gualivchenko
Permanent link to this post Posted by kozikowski » Mon Apr 09, 2018 3:59 am
OK.....Ummmmm.
That was the low-hanging fruit. The Scarlett seems to be working because you can hear it at the local headphone port. You can use Audacity to record the Mac built-in microphone.
There isn't much left. Can you try a different USB port? If you move the Scarlett, let it settle and restart Audacity.
Permanent link to this post Posted by kozikowski » Mon Apr 09, 2018 4:01 am
Is the Scarlett new? Did you personally pull off the shrink wrap?
Which Scarlett? There's only about a hundred of them.
Permanent link to this post Posted by gualivchenko » Mon Apr 09, 2018 12:23 pm
Scarlett Focusrite 18i20
I bought it new back in 2016. I worked fine before. I will try to test it in a diff computer / edit sw soon.
gualivchenko
Permanent link to this post Posted by kozikowski » Mon Apr 09, 2018 1:59 pm
24-bit/192kHz
It's possible Audacity or something else in the digital system can't handle those high numbers. That's over four times higher than the default sample rate.
Permanent link to this post Posted by gualivchenko » Mon Apr 09, 2018 3:48 pm
TIL
Changing the project rate to 192 Hz fixed it!
Thank you!!!
gualivchenko
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
