Unknown "Envelope" Mode Entered
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by BillDeL » Sat Apr 07, 2018 7:17 pm
macOS 10.13.4
Audacity 2.2.2
While editing a label, I seemed to have inadvertently entered an unknown or undocumented mode associated with the track envelope window. See attached screen shot.
As shown, on the left side of the track envelope window there is a white vertical scale of some sort adjacent to the -1.0 - 1.0 amplitude scale.
I can't seem to clear this mode or function. I can adjust the envelope in this mode (see the menu that allows me to undo "envelop"). I can't find any reference in the user guide about this function. Creating new projects doesn't clear this mode, and upgrading Audacity software didn't clear it either.
Can any one tell me what mode this is and how to get out of it?
Thanks.
Screen Shot 2018-04-07 at 3.02.36 PM.png (411.37 KiB) Viewed 123 times
BillDeL
Re: Unknown "Envelope" Mode Entered
Permanent link to this post Posted by kozikowski » Sat Apr 07, 2018 9:55 pm
Envelope Mode is the center-top tool. The normal selector is the "I-Beam."
Screen Shot 2018-04-07 at 14.53.29.png (11.64 KiB) Viewed 121 times
Permanent link to this post Posted by steve » Sun Apr 08, 2018 1:00 am
You've selected the "multi-tool" (see: http://manual.audacityteam.org/man/multi_tool.html)
To get back to the normal "Selection tool" (http://manual.audacityteam.org/man/selection_tool.html), click the "I" cursor button.
Permanent link to this post Posted by BillDeL » Sun Apr 08, 2018 1:22 pm
Yes, thanks. I figured that out about 10 minutes after I posted the issue. :roll:
BillDeL
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
