The type of noise "Click removal" unable to remove
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by paige_ninguru » Fri Apr 06, 2018 5:23 am
Hi! I have a question about getting rid of a noise happens more than once in my voice recording - the noise sounds like "dot"(I've attached that segment here) which is too short for "click removal" to recognize the flaw. So when I used that function, my voice's volume generally goes down and the "click" sound still persists.
I know one of the ways would be just deleting that portion and re-recording the line. Since it happens from time to time in my podcast recording, I wonder if there will be any other fix.
Also, is there's any way to avoid that kind of glitch? That kind of noise doesn't happen during my recording but when I re-listen to it. Thanks!!!
glitch.mp3
(10.39 KiB) Downloaded 7 times
paige_ninguru
Re: The type of noise "Click removal" unable to remove
Permanent link to this post Posted by Trebor » Fri Apr 06, 2018 11:27 am
paige_ninguru wrote:... is there's any way to avoid that kind of glitch? ...
There's a tiny bit of audio missing, but no silent gap , so it's a buffer problem, see ... viewtopic.php?p=343781#p343781
glitch, Before-After repair.wav
repair not invisible as there is a piece missing
(166.62 KiB) Downloaded 5 times
Trebor
Permanent link to this post Posted by paige_ninguru » Fri Apr 06, 2018 11:42 pm
Thanks Trebor for your advice, your workaround file sounds perfect to me but I still fail in my part...I tried to set the buffer length to zero, more clicky sounds occurred; then I tried increasing the value, I found before and after ~20, the result was either more clicky sounds or just like my original file. How did you do to clean that sound? Appreciated your help!!
Screen Shot 2018-04-06 at 18.24.58.png (193.36 KiB) Viewed 110 times
Reason: Put image inline to preserve board layout
paige_ninguru
Permanent link to this post Posted by Trebor » Sat Apr 07, 2018 1:14 pm
paige_ninguru wrote: How did you do to clean that sound?
Manually, see ... http://manual.audacityteam.org/man/click_removal_using_the_spectrogram_view.html
If there is a piece missing the repair will probably still be noticeable.
Trebor
Permanent link to this post Posted by paige_ninguru » Sun Apr 08, 2018 3:15 am
Thank you so much! Got that now:)
paige_ninguru
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
