Audacity Plugin Download Issue
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Re: Audacity Plugin Download Issue
Permanent link to this post Posted by kozikowski » Fri Apr 06, 2018 9:10 pm
You can force Macs to hide filename extensions and that can cause many of the same problems it does on Windows.
Are you set to show the whole name? (attached).
From the desktop > Finder > Preferences > Advanced.
Screen Shot 2018-04-06 at 14.04.54.png (38.73 KiB) Viewed 109 times
Permanent link to this post Posted by evlys » Tue Apr 10, 2018 5:45 pm
kozikowski wrote:You can force Macs to hide filename extensions and that can cause many of the same problems it does on Windows.
UPDATE: I am now able to download the file and change the extension to .ny and activate for use as a plug-in in Audacity. Thanks for the input. Very helpful.
evlys
Permanent link to this post Posted by hydekids2 » Wed Apr 18, 2018 5:19 am
I am also having these exact issues and I do not know how to fix this. I'm using mac OS Sierra 10.12.6 and Audacity 2.2.2. ACX Check plug in turns to txt file. Even after changing it back to .ny. All help appreciated.
hydekids2
Permanent link to this post Posted by steve » Fri Apr 20, 2018 11:16 am
Ensure that your Mac is showing you the file name extension. It can get very confusing if the computer is hiding it.
See here for how to make a Mac show the file name extension: https://support.apple.com/kb/PH25381?locale=en_US
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 6 guests
