Reloading projects
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Reloading projects
Permanent link to this post Posted by LizZig » Thu Apr 05, 2018 6:43 pm
Mac OS 10.13.3 I am trying to reload a project and the data file is there but not the app file. Is there any way to retrieve it please.
LizZig
Re: Reloading projects
Permanent link to this post Posted by billw58 » Fri Apr 06, 2018 2:44 am
Audacity needs the MyProject.aup file and the MyProject_data folder (for example). The folder is useless without the AUP file. What happened to the AUP file?
-- Bill
billw58
Permanent link to this post Posted by LizZig » Fri Apr 06, 2018 3:45 pm
No idea, just seems to have vanished. It is not in the trash and I usually keep my files pretty well. I can only thinks I may have accidentally deleted it. If it had been an intentional delete, I would have done the data file too. Oh well, thanks for your help. Back to the drawing board.
LizZig
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
