Batch convert Stereo to mono
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by Danwan » Mon Mar 19, 2018 6:38 pm
Is there a way to Batch convert a number of mono ".MOV" files with these actions using CHAIN:
1 Open the file from a folder
2 Duplicate the Mono Track creating 2 identical mono tracks
3 Converting the 2 tracks in a stereo track and save it them as AIFF
However I also saw quoting a "Tools" macro which might be what I could use however I coldnt find it in my Mac Version 2.2.2
Any suggestions thanks
Danny
Danwan
Re: Batch convert Stereo to mono
Permanent link to this post Posted by kozikowski » Mon Mar 19, 2018 7:37 pm
Mono sound files play to both sides of your headphones. Is there any reason you insist on creating "Dual Channel Mono" (not really stereo).
I don't know if this exists in the Chains repertoire, but if you nudge the pan slider on the left just the slightest bit, an Export will be stereo in spite of the timeline only having one blue wave.
A note. Audacity doesn't save sound files. You have to Export to get one.
Permanent link to this post Posted by billw58 » Mon Mar 19, 2018 8:00 pm
In Audacity 2.2.2 you can create a Chain with one command - Export WAV - that can be used to extract the audio from MOV files.
You cannot convert the imported files to stereo and you cannot export to AIFF. The sample rate of the exported WAV will be the same as the sample rate of the imported MOV.
See this page in the manual for how to create and apply chains.
Chains have been renamed "Macros" in version 2.3.0 (which is under development).
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 8 guests
