Hey guys, I’m having a bit of a problem and I haven’t found a solution online yet.
I’m running Audacity 2.1.3 and trying to export a wav file at 16-bit mono 8000 hz. I resampled the clip I recorded into 8000 hz, set everything to mono and 16-bit, and exported signed 16-bit wav file. However, when I look at the info for the exported track, it still says the sample rate is 41000. Has anybody else encountered this issue and how do I fix it?
I’m running OS X El Capitan v 10.11.6 on a MacBook Pro.
