2.2.1 not recording audio
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by diskfunkshun » Mon Mar 12, 2018 8:22 pm
I'm running Audacity 2.2.1 on a macbook air (os x 10.13.3) with a pioneer djm-s9 mixer. I have the rca connectors plugged into the mixer's audio out and the 1/8" end plugged into the macbook's headphone jack but for some reason I'm not able to record audio. Any help is appreciated. thanks!
Re: 2.2.1 not recording audio
Permanent link to this post Posted by kozikowski » Mon Mar 12, 2018 8:42 pm
While you can force that to work poorly, it's likely to need special purpose sound adapters, it's easy to overload, clip and distort and it's mono, not stereo.
I use the Behringer UCA-202 on my Air.
It will plug into either computer type. That's my stereo mixer on the right.
My earlier MacBook Pros don't need it because they have real stereo recording connections (on the left).
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 2 guests
