Lost effect after upgrade
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by joedacity » Sun Mar 11, 2018 9:00 am
I installed a DeEsser nyquist effect when running v 2.1.1. When it didn't show up in effects menu, I searched forum and tried the Terminal command I found in https://forum.audacityteam.org/viewtopi ... 76#p322176.
After restarting Audacity, the effect was visible. I just upgraded to 2.2.2 and it's disappeared again. I tried repeating the same trick, but it didn't work.
Is there something else I need to do? Thanks!
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 2 guests
