Can't find Lame Library after installing
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Permanent link to this post Posted by skyscrapers » Mon Dec 18, 2017 8:00 am
Hi there,
we've tried several times to install the lame library. The problem is, that mac won't ask you for the installing target.
So the lame library is installed but we can't find it.
Help is appreciated,
thanks in advance,
Jan
skyscrapers
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
