Export Multiple Progress Window Moves
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by BillDeL » Sun Dec 17, 2017 3:58 pm
Audacity version 2.2.1
macOS 10.13.2
After selecting export multiple for Audacity project with labels used to delimit individual track files, and exporting to M4A format, the "export progress window" for each file disappears from view after the first file is exported. Subsequent progress windows can be found in different places behind other windows as each file completes.
Re: Export Multiple Progress Window Moves
Permanent link to this post Posted by waxcylinder » Sun Dec 17, 2017 5:15 pm
This is a known bug that we logged back in February but haven't been able to fix yet:
Because it is Priority P3 it is listed in the Release Notes
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 8 guests
