Saving a file using Export but can't get MP3
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by ehrcom2773 » Thu Dec 07, 2017 8:27 pm
Using Audacity 2.1.1 with macOS Sierra Version 10.12.6.
I have recorded a song. Trying to save the file using Export. Have downloaded and installed libmp3lame.dylib but my Macbook finder does not find an executable file and the Audacity program does not locate it to save the program to exportable format. What have I not done properly?
ehrcom2773
Re: Saving a file using Export but can't get MP3
Permanent link to this post Posted by billw58 » Fri Dec 08, 2017 3:26 am
First, please upgrade to the latest version of Audacity - version 2.2.1, available here https://www.audacityteam.org/download/mac/ .
Second, use the LAME installer (the DMG), not the ZIP file. The installer will put LAME in a place where Audacity can find it.
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
