Audio plays in VLC but is blank when importing
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by LFL » Sun Dec 03, 2017 8:53 am
Version of OS X: Sierra
Version of Audacity: Audacity 2.1.3
.dmg installer
Hi all,
I want to edit an interview that I recorded, and it plays fine on VLC but I cannot open it in Audacity to edit (see the attachment). It just appears blank when I import it.
My friends (who are using Mac and Windows) have the same issue with the recording, so I assume it's something to do with the audio file itself. Does anyone know why this is and how I can fix this?
We have used the recording device multiple times before and each time the recording has worked and is able to be imported into Audacity.
Thank you so much in advance!
All the best,
Ali
You do not have the required permissions to view the files attached to this post.
LFL
Re: Audio plays in VLC but is blank when importing
Permanent link to this post Posted by Trebor » Sun Dec 03, 2017 11:41 am
LFL wrote:My friends (who are using Mac and Windows) have the same issue with the recording, so I assume it's something to do with the audio file itself. Does anyone know why this is and how I can fix this?
Maybe the header on that particular WAV file is corrupted,
if so it's repairable, see ... https://www.youtube.com/watch?v=zaVr_WLikqs
Trebor
Permanent link to this post Posted by LFL » Sun Dec 03, 2017 12:43 pm
Thanks so much for your quick response! I followed the video and it didn't work, but after looking at other people's comments and suggestions, I tried to convert the audio in VLC and that worked a charm and I got it open on Audacity! Thanks again! :D
LFL
Return to Mac OS X
Who is online
Users browsing this forum: Google [Bot] and 14 guests
