Crash reports
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Crash reports
Permanent link to this post Posted by drchanowski » Fri Dec 01, 2017 11:07 pm
I'm operating on an iMac 2012 edition running macOS 10.12.6 with 32Gig of memory. I'm using Audacity 2.2.1
Is there a place here that I can submit crash reports for analysis? I have strange behavior when using the latest version of the app?
It begins randomly sounding like the record I'm recording is skipping but when I look at the app live feed I see that its as if I'm running out of memory.
Sound is gone for a fraction of a second, repeatedly and the gaps continue as grow larger until the app finally crashes.
I thought that someone might be interested in seeing the crash report to see what is happening and what needs to be done to address the problem.
Thanks.
drchanowski
Re: Crash reports
Permanent link to this post Posted by Trebor » Sat Dec 02, 2017 1:08 am
Trebor
Re: Crash reports
Permanent link to this post Posted by billw58 » Sat Dec 02, 2017 5:00 pm
You can post your crash report here. Either attach it as a text file, or paste it in-line in your message. If doing the latter, wrap the crash report in "Code" tags to make it easier to read.
-- Bill
billw58
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 9 guests
