cut and paste
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Re: cut and paste
Permanent link to this post Posted by blad » Thu Dec 07, 2017 1:52 am
billw58 wrote:How many characters are you attempting to paste into a label?
-- Bill
I never counted them. The examples I gave are a cross section of what I would enter. Songs and album titles are the best estimate I can give you and are what I primarily copy and paste.
blad
Re: cut and paste
Permanent link to this post Posted by billw58 » Fri Dec 08, 2017 3:37 am
Well, I've discussed this with the other support personnel here and none of us has a clue what is happening. None of us can reproduce the problem.
All I can suggest at this point is:
1) download and install the latest version of Audacity, available at https://www.audacityteam.org/download/mac/
2) in the Finder, go to ~/Library/Application Support/audacity and trash the "audacity.cfg" file; this will "reset" Audacity.
After that, try creating a label and typing some text into it. Does Audacity crash?
Then type some text into TextEdit, copy it, switch to Audacity, create a label, and paste it into the label. Does Audacity crash?
Copy some text from some arbitrary web site, switch to Audacity, create a label, and paste it into the label. Does Audacity crash?
Copy some text from discogs, switch to Audacity, create a label, and paste it into the label. Does Audacity crash?
I'm still trying to understand where things are going wrong.
-- Bill
billw58
Re: cut and paste
Permanent link to this post Posted by blad » Fri Dec 08, 2017 9:35 pm
billw58 wrote:Well, I've discussed this with the other support personnel here and none of us has a clue what is happening. None of us can reproduce the problem.
-- Bill
I will do this. Just 2 clarifications, does the new Audacity app copy over the old app when trashing the .cfg file? What is the latest version number?
blad
Re: cut and paste
Permanent link to this post Posted by billw58 » Fri Dec 08, 2017 9:42 pm
blad wrote: Just 2 clarifications, does the new Audacity app copy over the old app when trashing the .cfg file? What is the latest version number?
The latest version is 2.2.1.
I don't know what you mean by "does the new Audacity app copy over the old app when trashing the .cfg file". Trashing the cfg file resets Audacity. When installing a new version of Audacity into Applications you normally over-write the old version.
-- Bill
billw58
Re: cut and paste
Permanent link to this post Posted by blad » Sat Dec 09, 2017 6:18 pm
-- Bill
All clear. Maybe? I discovered a few issues that were totally regarding my procedure, I would cut/paste in this order> place my track label> select copy from alternative source> LEFT CLICK on track label>.THIS WOULD CAUSE THE APP TO CRASH) I would like to know what results you would have using this procedure. A working procedure is> place track label> select copy from alternative source> RIGHT CLICK (...bringing the app up) LEFT CLICK and paste. For me this is somewhat of nuisance because of such a slight nuance to the procedure.
Unrelated maybe . Im getting a very slight loss of sound. What is this?
Screen Shot 2017-12-09 at 12.47.53 AM.png (65.99 KiB) Viewed 43 times
blad
Re: cut and paste
Permanent link to this post Posted by steve » Sat Dec 09, 2017 6:31 pm
I don't know how to make a video capture on a Mac, so this is on Linux, but on Mac it works in exactly the same way:
(Click on the animation below to see the whole picture)
Re: cut and paste
Permanent link to this post Posted by blad » Sat Dec 09, 2017 8:52 pm
steve wrote:I don't know how to make a video capture on a Mac, so this is on Linux, but on Mac it works in exactly the same way:
Thanks Steve and Bill, For me and for now I'm considering this solved. However, I also realize that my problem was only related to my process. Audacity IMHO has a glitch regarding a failure occurring in too close proximity to a right and wrong procedure. Thank you because there is no way I could have resolved this without Audacities input.
blad
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
