Envelope Tool disabled 2.1.0
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by vorsoni » Fri Dec 01, 2017 12:34 am
I am using 2.1.0 on Mac Book Air Yosemite 10.10.5
I have 3 tracks combined in one file then I am trying to superpose a voice file over it.
To hear the voice I need to use the envelope tool to modulate the music tracks.
I was able to do so when the tracks were not combined. As son as I used the Time Shift Tool to bring 3 tracks one after another the envelope tool became disabled see screenshot attached
I can neither use the envelope tool on the music track nor on the voice track.
Has anybody been faced with this bug and if yes how did you fix it?
thanks
Val.
Screen Shot 2017-11-30 at 4.30.43 PM.png (934.89 KiB) Viewed 190 times
vorsoni
Operating System: OS X 10.10 Yosemite
Re: Envelope Tool disabled 2.1.0
Permanent link to this post Posted by kozikowski » Fri Dec 01, 2017 12:41 am
Are you in Pause? Lots of tools go away when you're in Pause.
Permanent link to this post Posted by vorsoni » Fri Dec 01, 2017 12:54 am
I had stopped to play the track but not clicked in pause....should I instal the new version instead?
thanks for your quick answer!!!!! you rock
vorsoni
Permanent link to this post Posted by kozikowski » Fri Dec 01, 2017 1:14 am
Are you sure you're not in Pause—click the keyboard P key? That's the only way I can get the forbidden symbol along with the Green position arrow and cursor in different places.
Click P again.
Permanent link to this post Posted by Paul L » Fri Dec 01, 2017 3:25 am
Did you report your version correctly, as 2.1.0?
That is several versions out of date.
Please confirm that you do not mean one of the release candidates of the recent 2.2.1.
I have not reproduced the problem in 2.2.1.
Paul L
Permanent link to this post Posted by Paul L » Fri Dec 01, 2017 3:27 am
I think Koz is right that there is a paused play in progress, because I see that the Stop button (the square) is bold yellow.
You can click that square button.
Paul L
Permanent link to this post Posted by steve » Fri Dec 01, 2017 11:12 am
Screen Shot 2017-11-30 at 4.30.43 PM.png (402.32 KiB) Viewed 178 times
Permanent link to this post Posted by steve » Fri Dec 01, 2017 11:16 am
Are you using Audacity 2.1.0 (as your topic title says) or 2.2.1 RC2 (as the forum board says)?
Permanent link to this post Posted by steve » Sun Dec 03, 2017 1:11 pm
steve wrote:Are you using Audacity 2.1.0 (as your topic title says) or 2.2.1 RC2 (as the forum board says)?
In the absence of a reply, I assume that it is Audacity 2.1.0, so I'll move this topic to the Mac forum.
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 6 guests
