freeze frame for audio
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Permanent link to this post Posted by quietleader » Thu Nov 30, 2017 6:47 pm
Hello,
I am using Audacity version 2.1.3.0 on Mac OS X 10.11.6 (El Capitan)
I've searched this forum and haven't found an answer to my question. My apologies if this has already been discussed.
Question: can Audacity sustain a note that is selected in a pre-recorded music file? This would be equivalent to creating a freeze frame in video.
The music file I'm working with is "Hey Jude" by The Beatles. I want to select any note in that song and freeze/sustain it for up to 10 seconds.
If this is not possible in Audacity, please let me know what alternatives might be available.
Thanks!
W.
quietleader
Re: freeze frame for audio
Permanent link to this post Posted by kozikowski » Thu Nov 30, 2017 7:25 pm
Video editors are repeatedly playing one video frame, so that's where the stuttering single note comes from. mamamamamamadedededededetutututututu.
Audacity doesn't have video frames, so there is no good reference.
I don't know of a good easy way to simulate that effect, either, short of repeatedly duplicating one single selected and copied note.
Permanent link to this post Posted by Trebor » Thu Nov 30, 2017 7:44 pm
quietleader wrote:Question: can Audacity sustain a note that is selected in a pre-recorded music file? This would be equivalent to creating a freeze frame in video.
Audacity has an effect called PaulStretch which will do that ...
Naaaaaaaaaah, via PaulStretch.flac
(543.15 KiB) Downloaded 7 times
The chorus effect on Paulstretch is unavoidable.
If you want the sustained note all at the same volume just repeat a short section, (it will sound like a glitched CD) ...
Naaaaaaaaaah, via Repeat.flac
(381.38 KiB) Downloaded 7 times
Trebor
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
