Creating gapless playback for digitization, not CD ripping
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Re: Creating gapless playback for digitization, not CD rippi
Permanent link to this post Posted by steve » Thu Nov 30, 2017 6:20 pm
strangetales wrote:Then I go to edit labels and create labels for the individual songs, with the previous song ending at the same time mark as the next song is beginning.
It sounds like you are using "region labels". Try using "point labels" instead. Then "Export Multiple" based on labels.
Permanent link to this post Posted by billw58 » Thu Nov 30, 2017 7:05 pm
I use a similar procedure. I export to AIFF (complete with metadata) then import the AIF files into iTunes. Then, within iTunes I convert to MP3. I have not experienced gaps in the playback.
iTunes 12.3.3.17 still has the File > Create New Version > Create Apple Lossless Version menu choice. The menu choice you get there depends on your setting in iTunes > Preferences > General > Import Settings.
-- Bill
billw58
Permanent link to this post Posted by strangetales » Thu Nov 30, 2017 8:17 pm
That was it -- I was (unknowingly) using region labels. Thanks so much for working this through with me -- I really appreciate it. There's no chance I ever would have figured that out. I really appreciate it.
strangetales
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 4 guests
