Recording is not complete after saving - Please help
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Re: Recording is not complete after saving - Please help
Permanent link to this post Posted by mauricevogels91 » Mon Nov 27, 2017 8:22 pm
steve wrote:
mauricevogels91 wrote:I do have all the .au files.
How do you know that?
Your right, I don't know that, but I do know that I have a map with different .au files. I read that sometimes, audacity won't load all the .au files if there is a error. So I thought that when I do this manually, I will have all the .au files that are on my laptop and have a chance to get my complete recording back
mauricevogels91
Permanent link to this post Posted by mauricevogels91 » Mon Nov 27, 2017 8:45 pm
billw58 wrote:
mauricevogels91 wrote:when I was listening it back, I heard that audacity had recorded the whole set, but skip true some numbers. For example, when a new number began, audacity skipped the track from the begin to the end. A few tracks after the skipped one are complete and then some tracks aren't.
That is totally bizarre. Audacity does not know about "tracks" or "songs".
Let me put it this way: I have a recording from my set (2h) and 2h from someone else which contains different tracks that are mixed together. Some tracks aren't complete in the recording, while the whole track has been played. Audacity skips some minutes of the set, but somehow it merged it together into one piece. What do you get? Skipped parts of some songs. Maybe this is more clear? if i look to the time frame: you don't see seconds or minutes that are lost. Also the strange thing is, that the last track at 3:55:00 is there (in this recording you hear it around 2:35:00?!)
mauricevogels91 wrote:when I stopped audacity, the recording was 3h and 55 minutes. But it isn't now
billw58 wrote: So something happened between the time you "stopped audacity" and "now". If the recording was showing 3h55m when you stopped it, then all that time was indeed recorded. About 1h25m has been deleted (not just silenced), and those deletions comprise selected songs from the recording. I can't imagine how a technical glitch in Audacity could cause that.
-- Bill
True! so it isn't the last part of the recording that is missing, of the first part etc. It are just many small sound pieces that are missing true the whole set (in this case tracks that aren't complete and you hear that Audacity skips some parts). But you hear the many tracks that are played (even the last track of the second set), but from min 18 to the last part, you hear tracks that are not complete (while they were played completely).
i'm affraid that I just lost the parts because what I read from everyone, this is not a familiar complaint (for example a bug or something). But it is so strange. I use Audacity for a long time, even with the same audiocard. This is really the first time something like this happend to me.
Thanks anyway, really appreciate it!
Last edited by mauricevogels91 on Mon Nov 27, 2017 11:18 pm, edited 2 times in total.
mauricevogels91
Permanent link to this post Posted by billw58 » Mon Nov 27, 2017 10:56 pm
mauricevogels91 wrote: I have a map with different .au files.
What do you mean by "map". How do you know they are "different"? Different from what?
At any point in this process, did Audacity give an error message when opening the project?
-- Bill
billw58
Permanent link to this post Posted by mauricevogels91 » Mon Nov 27, 2017 11:13 pm
-- Bill
No error messages at al. I mean with different just a lot of small audiofiles (see picture). I think this is normal, because it look familiar with other times.
.au files
Screen Shot 2017-11-28 at 00.11.14.png (57.12 KiB) Viewed 146 times
What i do notice is that Audacity do not open all the .au files. I was trying to open some .au files. Some files Audacity opened (could even listen to the fragments), but at some files Audacity wasn't responding at al and I had to use the "force quit" option from mac.
Last edited by mauricevogels91 on Mon Nov 27, 2017 11:30 pm, edited 1 time in total.
mauricevogels91
Permanent link to this post Posted by steve » Mon Nov 27, 2017 11:28 pm
If that is a raw recording with no editing at all, the folders d00, d01 .. d0a should all be the same size, the final folder d0b is likely to be smaller.
What size are they (including their contents)?
If there are more .AU files in the data folder than are required by the project, Audacity will throw a warning about "orphan block files" when you first try to open the project.
If there are less .AU files in the data folder than are required by the project, Audacity will throw a warning about "missing block files" when you first try to open the project.
Did we establish whether the "missing" parts of the recording are periods of silence (as if the recording level was temporarily set to zero during the recording), or completely missing (as if the recording was stopped and then resumed)?
How many separate bits are missing?
Is it always complete songs that are missing?
Permanent link to this post Posted by mauricevogels91 » Tue Nov 28, 2017 12:01 am
steve wrote:If that is a raw recording with no editing at all, the folders d00, d01 .. d0a should all be the same size, the final folder d0b is likely to be smaller.
The sizes of the folders:
d00: 271.604.736 bytes (272,6 MB on disk) for 257 items
d0a: 271.604.736 bytes (272,6 MB on disk) for 257 items
d0b: 196.544.064 bytes (197,3 MB on disk) for 187 items
d01 up to d09: 271.604.736 bytes (272,6 MB on disk) for 257 items
steve wrote:If there are more .AU files in the data folder than are required by the project, Audacity will throw a warning about "orphan block files" when you first try to open the project.
Haven't had a error message as far as I know. Maybe that I missed it, but I really doubt it, because I opened for the first time yesterday (after saving and exporting it Saturday)
steve wrote:Did we establish whether the "missing" parts of the recording are periods of silence (as if the recording level was temporarily set to zero during the recording), or completely missing (as if the recording was stopped and then resumed)?
second, as if the recording was stopped and then resumed. But the strange thing is that while I was performing or the other guy, nobody touched my laptop. It even didn't go on sleeping mode or something..
steve wrote:How many separate bits are missing?
hard to say, because it are some parts during the recording. have a example of a skipped track here: this is around the 1:45h (the first 2h it happend around the 4 times, but in the second part it is almost at every track).
drift festival fragment.mp3
Fragment of recording
(419.18 KiB) Downloaded 8 times
As you can hear, it looks like at some parts someone pressed the stop button and resumed or something. But this is not the case, it just can't be. I was there all the time.. oh and ps. I know you guys don't know the track, but still you can hear that it skips true the number I think? otherwise I can upload a larger part if necessary.
steve wrote:Is it always complete songs that are missing?
Not always, first 2h just 4 times but the second two hours are almost complete failure like the example I gave (listen to fragment above).
mauricevogels91
Permanent link to this post Posted by billw58 » Wed Nov 29, 2017 11:26 pm
mauricevogels91 wrote:What i do notice is that Audacity do not open all the .au files. I was trying to open some .au files. Some files Audacity opened (could even listen to the fragments), but at some files Audacity wasn't responding at al and I had to use the "force quit" option from mac.
That is also bizarre. You apparently have damaged .au files in the _data folder. If Audacity crashes when trying to open them I'd expect Audacity to crash when trying to play them as part of a project.
What is the file size of the damaged .au files compared to good ones?
-- Bill
billw58
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 7 guests
