Overdrive removal
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Overdrive removal
Permanent link to this post Posted by Audacityisfun » Sat Nov 25, 2017 7:53 pm
Hi, I have recorded an audio file with Audacity with the internal microphones of my Macbook Pro during a concert. Unfortunately, it was very loud in the room and I did not adjust the input level, so the resulting file is totally overdriven in volume. Is there a filter I can use which can maybe reduce the clipping and interpolate the volume so it will sound better? THX for replies!
Audacityisfun
Re: Overdrive removal
Permanent link to this post Posted by kozikowski » Sun Nov 26, 2017 1:54 am
Export > WAV (Microsoft) to make a safety copy of the show before you do anything else. Put the copy in a safe place. If the stereo show went over three hours, export it as the highest possible quality MP3.
View > Show Clipping.
Did the timeline turn into a sea of red?
If it did, that's the end of the world.
There is a Clip-Fix tool, but it repairs a tiny part of a musical note and it uses the healthy work on both sides to do it. If you have no healthy work, that's it.
Drag-select about ten seconds of it, export as WAV and post it here.
viewtopic.php?f=49&t=72887
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 3 guests
