Voice Vibration Effect - "Purr"
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
and the exact three-section version of Audacity from "Audacity menu > About Audacity".
Permanent link to this post Posted by EFE_W » Mon Nov 20, 2017 5:30 am
Hi all!
I've had a hard time trying to find information about this and hope I can get some pointers here. Kinda desperate :-s
I have a cute cartoony voice file that says "yay" and I want to make it sound like an cute alien creature, similar to this: https://www.youtube.com/watch?v=XSxXGCUqra4
The result I want is to have a cute alien creature voice that sounds like a purr. I see plenty of resources for creepy monsters stuff but nothing for sweet and cute. Wonder if this would be achieved with a filter that makes the sound vibrate or if the sound has to be overlaid with a purr sound effect and auto tuned?
So many thanks in advance!
My specs:
Audacity 2.2.0
Mac OS 10.13.1, High Sierra
EFE_W
Re: Voice Vibration Effect - "Purr"
Permanent link to this post Posted by Trebor » Mon Nov 20, 2017 4:43 pm
EFE_W wrote:... a filter that makes the sound vibrate ...
If you copy & paste this code into Audacity's Nyquist prompt ...
Code: Select all
(scale 0.6 (sim (mult *track* (fmosc 27.0 (hzosc 27)))))
Then apply Nyquist prompt like any other effect, it adds a purr-ish effect ...
before-after-after.flac
(268.73 KiB) Downloaded 16 times
If you want it to be cute you may have to shift the pitch up by about 50% before applying the code.
Trebor
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 5 guests
