intermittent record
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
intermittent record
Permanent link to this post Posted by blad » Sun Nov 19, 2017 11:10 pm
Every thing is good to go until i record. It functions for a time then stops and will pick back up 10 -15 sec later. The result is skipped record. Anyone please advise. Thank You.
OS X 10.7.5 mac pro
blad
Re: intermittent record
Permanent link to this post Posted by kozikowski » Sun Nov 19, 2017 11:35 pm
You're transferring vinyl records? How? How are you playing the records?
Permanent link to this post Posted by billw58 » Mon Nov 20, 2017 12:40 am
Have you accidentally enabled Sound Activated Recording ?
-- Bill
billw58
Permanent link to this post Posted by blad » Sat Nov 25, 2017 5:27 am
kozikowski wrote:You're transferring vinyl records? How? How are you playing the records?
I'm not sure what is being requested here but, yes, i am transferring records. I cue my record > set pause and record with audacity > start record.On side change I pause on record> cue next side and continue and so on..... I'm sure this is permissible. If not, please advise me what other procedure is better.
Thanks
blad
Permanent link to this post Posted by blad » Sat Nov 25, 2017 5:29 am
billw58 wrote:Have you accidentally enabled Sound Activated Recording ?
-- Bill
Thanks Bill
Sound activation is not engaged.
blad
Permanent link to this post Posted by blad » Sat Nov 25, 2017 5:41 am
-- Bill
Thanks Bill
The overdub is checked on, the software playthrough is checked on.
blad
Permanent link to this post Posted by blad » Sat Dec 02, 2017 6:29 am
I'm adding to this post again because the intermittent episode just occurred again. This really needs to be more reliable. Transferring records is tedious enough. If the problem was predictable it could be fixed. Imagine, transferring records for 8hrs and find that there are 5 sec drops here and there throughout the 8 hours. It becomes lost time. If Audacity 2.2.0 would just stay stopped, then I could simply re cue. When monitoring the recording I hear only the record album. I think the actual transfer is only audible with finished recording. I can conclude by stating my anxiety level is peaked with this. I have no idea that of the 700+ albums transferred with the help of Audacity, that there might be 5000 5 second gaps throughout. The saving grace is I do check the transfers, but not real time. If anyone has any ideas regarding this please let me know. Thanks
blad
Permanent link to this post Posted by billw58 » Sun Dec 03, 2017 3:16 am
We should have asked earlier: What version of Audacity are you running?
Also: How are you connecting your turntable to the Mac Pro? Line In? USB?
For the moment it appears all the elves are stumped.
-- Bill
billw58
Permanent link to this post Posted by kmg » Mon Dec 04, 2017 8:44 am
Hey,
I'm also having the same problem, but I'm recording old radio plays from cassette tapes. I've attached a screen shot showing the discrepancy between the track time and the audio position. Any suggestions gratefully received!
Screen Shot 2017-12-04 at 08.35.05.png (370.25 KiB) Viewed 180 times
kmg
Permanent link to this post Posted by billw58 » Mon Dec 04, 2017 5:47 pm
kmg:
Try the stuff recommended in this FAQ
-- Bill
billw58
Next
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 8 guests
