Options when exporting as MP3 no longer working
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Please state which version of OS X you are using, the exact three-section version of Audacity from Audacity > About Audacity and whether you obtained the .dmg installer or the zip.
Re: Options when exporting as MP3 no longer working
Permanent link to this post Posted by RpgAcademy » Sun Nov 19, 2017 8:37 pm
audacity is 2.1.1
I don't have those same options.
SAVE is greyed out, can't select.
SAVE AS only gives me option to save as audacity file.
Screen Shot 2017-11-19 at 3.36.22 PM.png (151.86 KiB) Viewed 118 times
RpgAcademy
Permanent link to this post Posted by steve » Sun Nov 19, 2017 9:03 pm
In Audacity 2.1.1, select "File menu > Export Audio...".
Permanent link to this post Posted by RpgAcademy » Sun Nov 19, 2017 9:07 pm
Right. That's what i'm doing. But there is a button that says 'options' which in the past i've clicked on then reset the KB rate from standard 128 down to 98 or 80 (depends on the length of the track) to get it under my hosting site's 65 mb limit. But what i'm saying is that when I go there - the 'option' button doesn't work. It am unable to click on it. Nothing happens. it's not like i'm clicking and there are no options or the wrong options. It's like that button is not clickable.
RpgAcademy
Previous
Return to Mac OS X
Who is online
Users browsing this forum: No registered users and 6 guests
